I want to develop a new plugin that would extend Microstation. I want my plugin to create new elements in the DGN file that would show up graphically for people that dont have the plugin but that would be editable with more feature and information for the people with the plugin. Like Open Rail works on top of Microstation or C3D on top of ACAD.
I was going to start a prototype in VBA to show my bosses and coworkers before going deeper and migrating to .NET.
Do you think it's possible with VBA or should I move from the start to MDL or .NET?
-Alex
Hi Alex,
Unknown said:Do you think it's possible with VBA or should I move from the start to MDL or .NET?
You did not write for what MicroStation version do you plan to develop you application (V8i, CONNECT Edition...) and how complex (in terms of graphical structure and behaviour) your objects will be, so my comments are based on general assumptions:
In my opinion APIs should be combined: To use C/C++ API to implement complex functionality and WinForm (in V8i) or WPF (in CE) to implement GUI. C++/CLI can be used to create wrappers between these two worlds (native and managed).
With regards,
Jan
Unknown said:It's good to know the .NET API is still at early stages
In fact there is not real NET API in MicroStation V8i, but Interop is used.
Unknown said:coming from ACAD I was expecting it to be more developed.
That is completely wrong assumption and comparison. In MicroStation always native C/C++ code was defined as primary API. It makes sense, because only native code can ensure 100% speed, not managed API requiring a lot of marshalling and time consuming memory allocation. The situation is much better in CONNECT Edition, but even in this version NET API is not designed as C++ API replacement.
C++/CLI is good alternative if you prefer to be in managed world but need to use full MicroStation API, because you can use managed and native code in the same project and to create wrappers to be referenced by a pure managed code (C#, VB.NET...).
