Extract Line String Coordinates with VBA
We begin transforming our Micro Station Basic Macros into VBA.
We have a three points Line string.
Is there a very simple example in VBA on how to extract all its vertices coordinates?
Apparently with
Dim vertices() As Point3d
vertices = oElement.AsVertexList.GetVertices)
But all Micro Station VBA help examples are not clear at all, on which code to write in the module and which code to write in the class module.
  • it is up to you how you design your modules and or classes. for easy things a module maybe enough if your ideas grow classes are best.
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Esri ArcMap, AutoCad Bentley MS V4 - V8i, GeoGraphics, Map, InRoads  HHK Geograf, IBr DAVID,  AED-SICAD-Utilities ]  Dev: [C, C++, Basic , Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
