MS VBA - How to Retrieve Element Property
I referenced a shapefile into a dgn. I copied an element from the shapefile into the dgn. I see that the shapefile element attributes/properties are now in the dgn. How can I access one of the properties (CONTOURELE) in VBA?
Thank you.
