It has been a very VERY long time since I had to do anything in MVBA. All I need is an example or point me in the right direction. I'm trying to setup a VBA that will turn on the Level Overrides then turn on specific levels overrides and set the color. I want to, set all of the levels that have existing elements to a very light gray and fade them back. I don't mind doing research so any help would be appreciated. I just need to know a direction to start looking.
Thank you
Phillip Hess
Hi Phillip,
in VBA overy level definition (object) has:
Similarly every view has DisplaysLevelSymbology property, that is equal to View Attribute setting.
With regads,
Jan
Jan, I apologise for not thanking you for the information. I was pulled off on another project and am just now getting back to this project. Thank you for the information it is very helpful and gives me a direction too with.
