How to Get Global Origin of the DGN?
Dear all,
                 I am using Microstation v8 2004 Edition i trying to get the global origin of the DGN i am using using the ActiveModelReference.GlobalOrigin function and i get the x,y and z value but the value is mismatched  with the GO=$ command values.
EX:
        ActiveModelReference.GlobalOrigin Values:
                               x=110648850, y=-141411270800, z=0
GO=$ command values:
x=90325.2999, y=-5570551.4861, z=85899.3459
Note:
Here i attached my empty dgn please find it.
Thanks & Regards,
Karthik M
3p0125025.dgn
  • IMHO you get UOR instead of working units with ActiveModelReference.GlobalOrigin.
    if you search the MVBA help for UOR you will get help, other properties and methods to get a solution.
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Esri ArcMap, AutoCad Bentley MS V4 - V8i, GeoGraphics, Map, InRoads  HHK Geograf, IBr DAVID,  AED-SICAD-Utilities ]  Dev: [C, C++, Basic , Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
