Extracting values from data fields existing in a cell border.
Hi I'm looking for something simple to extract a specific part set of data fields from a drawing border.  The border exists as a .cel in the drawing and there are four data fields i would like to extract to excel preferably.  The data fields are numbered "D_SIZE_7567"  and so on thru 70.  Any help in writing a simple macro would be appreciated.  FYI very little experience in writing macros.  Version: MS v8i
  • if you share a small sample DGN everybody may help you better. and better understand your way looking for "data fields".
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Esri ArcMap, AutoCad Bentley MS V4 - V8i, GeoGraphics, Map, InRoads  HHK Geograf, IBr DAVID,  AED-SICAD-Utilities ]  Dev: [C, C++, Basic , Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
