Dear all,
In the attachment, Green and Red elements represents the two different shape elements. I need to get the angle between them. Is there any inbuilt method available?
an angle between planar objects (mandatory condition) is an angle between their normals. So takes normal (it's the property of shape element) and count angle between them.
If you are not ensure the shapes are planar, the situation has no simple solution.
With regards,
Jan
