V8i Printing to PDF using VB.NET
Hello there guys, Good day.
I have a project that watches a certain directory for DGN files to be printed as they are copied. I've read a couple of examples in VBA on how to print to PDF, but I'm having trouble distilling these examples into my code.
I've already written the code that does the monitoring, the only stuff that's missing is the code to print the DGN files to PDF.
Any help on this matter is highly appreciated.
Cheers,
Public Class DirectoryMonitor
	Dim FolderWatcher as FileSystemWatcher
	Public Sub New()
		'Initialization
		FolderWatcher = New FileSystemWatcher("D:\PdfConversion", "*.dgn")
		FolderWatcher.IncludeSubdirectories = True
                'Event handler for newly created files
		AddHandler FolderWatcher.Created, AddressOf FolderWatcher_Created
	End Sub
	Public Sub StartMonitoring()
                ' Start Watching
		FolderWatcher.EnableRaisingEvents = True
	End Sub
	Public Sub StopMonitoring()
                ' Stop Watching
		FolderWatcher.EnableRaisingEvents = False
	End Sub
	' Call this function everytime a DGN file gets copied to the monitored folder.
	Private Sub FolderWatcher_Created(sender as Object, e As FileSystemEventArgs)
		Dim dgnFileName = e.FullPath
		' Code to print to PDF should go here
	End Sub
End Class
  • Rebuild your app. as a MicroStation AddIn (DLL), not an executable. Connect to MicroStaton using the MicroStationDGN.Application via a .NET InterOp. Now you can use the classes and methods provided by MicroStation VBA.
    VBA Help
    VBA help is comprehensive and includes many examples. What you need to do is queue the same print commands that you would use in MicroStation to create a PDF.
    Regards, Jon Summers
    LA Solutions
  • Hello Jon,
    Thanks for your advice, but rebuilding the app as an AddIn is not appropriate, I think. Since this app will implemented as a Windows Service for an In-House DGN to PDF conversion server.
    I've tried fiddling with Microstation's Interop DLL, and I was able to generate PDFs from every DGN that is copied to the monitored folder. The only problem is, the output PDF gets saved to C:\Windows\SysWOW64.
    	Dim App as Application;
    	Public Sub New()
    		'Initialization
    		App = new Application()
    		App.ActiveWorkspace.AddConfigurationVariable("MS_PLTFILES", "D:\OutputPDF"); ' Set Output Folder
    	End Sub
                    ' Start Watching
    	End Sub
                    ' Stop Watching
    	End Sub
    		Dim dgn = App.OpenDesignFile(dgnFileName, true)
    		Dim paperSize = "ISO_A3"
    		app.CadInputQueue.SendKeyin("MDL LOAD PLOTDLG")
            app.CadInputQueue.SendKeyin("PRINT DRIVER pdfx.pltcfg")
    		app.CadInputQueue.SendKeyin("print boundary fit all")
    		app.CadInputQueue.SendKeyin("print papername " & paperSize)
    		app.CadInputQueue.SendKeyin("print colormode monochrome")
    		app.CadInputQueue.SendKeyin("print maximize")
    		app.CadInputQueue.SendKeyin("print execute " & System.IO.Path.GetFileName(dgnFileName) & ".pdf")
    	End Sub
    End Class
    MicroStation sends print output to a destination specified by configuration variables.  See Printing Configuration Variables in MicroStation help.
    Folder paths, such as MS_PLTFILES, must be terminated correctly...
    App.ActiveWorkspace.AddConfigurationVariable( _
       "MS_PLTFILES", "D:\OutputPDF\")
    LA Solutions
    PMFJI, but you should take a look at the End-User License Agreement, particularly about the use of a desktop application as a server-based application. That said, we do have a server-based system that may provide the functionality you are looking for -- it is called ProjectWise InterPlot.
  • I see. This was being done in another company, so I thought it was a-ok to do something like this.
    I will cease my activities, then.
