Are there functions availble in straight mdl to create dynamic views or can this only be done with the Microstation API? My manual procedure is to create some plan sheets based on existing borders by using the 2 point save view command and selecting the create drawing option to create my sheet models.
Ray
The CompositionBuilder is all C++ native code api. The option is to drive the tool through its commands.
HTH,
mark anderson [Bentley]
Visit me at https://communities.bentley.com/communities/other_communities/bentley_innovation/default.aspx
Mark,
where can I find examples using the compositionBuilder?
