Can closing file be canceled?
I tried to prevent user closing dgn file if a certain task hasn't been finished using C#.
Is there an event handler on file closing and some parameter can be set so that the closing action can be canceled?
Gang
  • In C (aka MDL):
    Private int     queueMonitor
    Inputq_element     *qeP  /* <=> pointer to queue element */
        if ( qeP->hdr.cmdtype == CMDNUM )
            switch ( qeP->u.cmd.command )
                 case CMD_EXIT:
                 case CMD_NEWFILE:
                 case CMD_CREATE_DRAWING:
                 case CMD_DIALOG_OPENFILE:
                 case CMD_EXCHANGEFILE:
                 case CMD_CLOSE_DESIGN:
                 if ( cancelDrawingClose )
                    return INPUT_REJECT;
                 break;
        return INPUT_ACCEPT;
    // establish hook
            mdlInput_setMonitorFunction ( MONITOR_ALL,       queueMonitor );
    Cheers,
    /Chris Z.
  • Chris,
    Thanks for your coding using MDL. Can that be implemented in C#? Since our current Add-in is written in C#.
    Gang
  • Hi Gang,
    I don't think so, I see no wrapper for mdlInput_setMonitorFunction in MDL help file. In the past (I am not sure if in this forum or in BDN community)  alternatives what to do if a wrapper is missing were discussed, but it's not an easy way and it requires deep knowledge from more areas.
    You have to accept today C# API (which is not "true NET API" but VBA/COM) is limited and C/C++ is the only way to receive maximum functionality. What about to create small MDL app, which will be loaded and controled (using key-ins) by your add-in and which will block a file unloading process?
    With regards,
      Jan
    Answer Verified By: Gang
Reply Children
