i currently have this code in one of the macros for work. It is located under a button for browsing which folder to look into, and it will get the .DGNs and add them to a listbox.
I don't quite understand the code fully and was hoping someone can give me a quick run down. Also, the code only looks at the selected folder for .DGNs, i want it to look into sub folders as well, is that possible?
Dim myFSO As New Scripting.FileSystemObject Dim myFolder As Scripting.Folder Dim myFile As Scripting.File Dim myShell As New Shell32.Shell Dim myRootFolder As Shell32.Folder3 Set myRootFolder = myShell.BrowseForFolder(0, "Pick", 0) If myRootFolder Is Nothing Then Exit Sub Set myFolder = myFSO.GetFolder(myRootFolder.Self.path) txtCurrentFolder.Text = myRootFolder.Self.path lstFilesInFolder.Clear For Each myFile In myFolder.Files Select Case UCase(Right(myFile.Name, 3)) Case "DGN" If IsFileIn(myFile.path, lstFilesToProcess) = False Then lstFilesInFolder.AddItem myFile.path End If End Select Next
Unknown said:I don't quite understand the code fully and was hoping someone can give me a quick run down
Your code has little to do with MicroStation — it's generic Windows folder searching. You can find plenty of information about that on Microsoft and other forums that deal with VB/VBA/VBScript. Some are mentioned here. Probably a good place to start would be wherever you found your code.
Step throught the code in debug using function key 8 (F8).
