[V8i VB.NET] CreateLineElement
I'm using Microstation COM in a .Net app (I'm porting my Vehicle Turning Simulation MSTurn from classic VB6). I've noticed that creating Linestrings is a rather slow process since I need to provide data with the Point3DfromXYZ. My calculated values for the linestring are stored in a Array and it would be nice if I could eliminate looping through the array to create points using Point3DfromXYZ
I've seen functions in other CAD systems (Intellicad) that has functions for converting arrays of doubles to collections. I can't find anything similar in Microstation (COM). Is it possible to build a LineString from a array of doubles?
  • Unknown said:
    It would be nice if I could eliminate looping through the array to create points using Point3DfromXYZ
    MicroStation APIs (MDL, VBA) work with 3D data.  The Point3d data type is the foundation of 3D geometry.  If source data is in some other format (e.g. parallel arrays of X,Y coordinates) then you must convert those to an array of Point3d.
    Unknown said:
    I've seen functions in other CAD systems for converting arrays of doubles
    It's simple enough to write your own conversion.  If another API provides something similar you will recognise that it's just a convenience function.
    Unknown said:
    I've seen functions for converting arrays to collections
    Collection means a particular type of data container.  The collection provided by VB/VBA is notoriously slow.  For what you want to achieve, a collection is unhelpful.  If you already have an array of data, then looping through that set is quicker than using a collection...
    Sub ConvertDoubleToPoint3dArray ( _
           ByRef points() As Point3d, _
           ByRef x() As Double, _
           ByRef y() As Double, _
           ByVal nPoints As Long)
      Redim points (0 to nPoints-1)
      Dim i As Long
      For i = 0 To nPoints -1
        points(i) = Point3dFromXY (x(i), y(i))
      Next i
    End Sub
    Regards, Jon Summers
    LA Solutions
  • I would like to avoid the looping, I already have a array of doubles. I was hoping for one call to the COM object instead of hundreds while creating every point. AutoCADs function for creating Polylines accept a plain array of doubles as a parameter and its very fast. In Microstation I need to convert the array to Point type first (looping)
    Yes the collection is slow, that's probably the reason for Intellicad providing a function for converting arrays of doubles (like AutoCAD) to collections of points. My app produce a lot of linestrings (sweep od vehicle) and I would like to get same speed as I get with AutoCAD's COM object.
    OK — I can imagine that would be slow.  Is your .NET application an exe or a dll?  An exe will be calling MicroStation VBA using Microsoft COM's marshalling across the process boundary, which adds substantially to the overhead.
    But why not build the array of Point3d in your .NET app.?  If the Point3dFromXY call is slowing things down, then do it directly to avoid that COM call...
      Dim i As Long
        points(i).X = x(i)
        points(i).Y = y(i)
        points(i).Z = 0
      Next i
    End Sub
    LA Solutions
    Answer Verified By: Lars Karlsson
