[VBA] Error 424: Object Required
Can anyone please let me know why my code is not working?  I keep receiving Error 424:  Object Required.  I'm pretty new to VBA and coding so it might be something very simple.  This is what I would like my code to do:
  • There are text elements in a level.
  • The text content are numbers (1, 2, 3, 4, etc.).
  • I want to be able to select one text element, parse its content as a number and attach this number to a defined general URL.
  • The result should be attached to the selected element as URL link.
This is my code:
Sub Init()
  Dim oText As TextElement
  Set oText = ElementEnumerator.Current.AsTextElement
  Dim content As String
  content = oText.Text
  CreateLink content
End Sub
Sub CreateLink(ByVal content As String)
  Dim strURL As String
  strURL = "http://www.google.com" & "/" & content
  Debug.Print "My URL=" & strURL
  CadInputQueue.SendKeyin "ELEMENT CREATE LINK URL " & strURL
End Sub
  • You should see the line which causes the error and tell it us...
    But this case seems pretty simple: Neither You've declared the variable ElementEnumerator nor did You assign any value to it - at least not in the code we can see here.
    Robert
  • Thank you for the quick tip Robert.
    Here is what I think you are saying is the solution (with this change I am now getting a different error though):
    Sub Init()
    Dim ee As ElementEnumerator
    Set oText = ee.Current.AsTextElement 'The error is now occurring here (Run-Time error '91': Object variable or With block variable not set
    CreateLink content
    End Sub
    End Sub
    You've declared a variable named ee.  It's a reference to a class of type ElementEnumerator.  Right now, you haven't initialised that object: it's an empty chunk of memory.  That explains the error message.
    An ElementEnumerator is used to enumerate elements.  The question is "What elements do you want to enumerate?"  Often, you want to scan a DGN model to examine its graphic elements.  The Scan method of ModelReference does exactly that and returns a valid ElementEnumerator.  Look that up in VBA help, and write something like this:
    Set ee = ActiveModelReference.Scan
    Do While ee.MoveNext
      Dim oElement As Element
      Set oElement = ee.Current
      If oElement.IsTextElement Then
        Dim oTextElement As TextElement
        Set oTextElement = oElement.AsTextElement
        '  Now you can use the properties and methods of TextElement
        Debug.Print "Text=" & oTextElement.Text
      EndIf
    Loop
    Regards, Jon Summers
    LA Solutions
  • Jon,
    First, thanks for all the help. I've looked up every word of code you have helped me with so far in the MicroStationVBA.chm and I've really developed a good understanding of what is happening when I run this VBA. But there is one thing that I cannot get around, I cannot select a text element, run the macro, and have that text element attach to the general URL in the code. Instead, only the most recently created text element will attach itself to the general URL in the code. Example: I use the Place Text tool to create a text element that displays the following text, TEST, then I select a different text element and run the VBA and a get a link attached to that text element that reads www.generalURL.com/TEST. I've searched the VBA Help index high and low looking for a way to parse out only the text of the element that I currently have highlighted. I keep delving deeper and deeper into selection set tutorials, but I can't seem to find anything. Here is the code as it is:
    Sub Init()
    End If
    Loop
    content = oTextElement.Text
    CreateLink content
    End Sub
    End Sub
    Do you see any reason why this is happening?
Reply
  • Jon,
    Sub Init()
    End If
    Loop
    CreateLink content
    End Sub
    End Sub
