mdlElmdscr_copy element color issue
In a function I wrote, I need to copy element from a workdgn to another work dgn. When I open the file where elements have been copied, element color are altered. For example, color 22 in the first workdgn becomes 6 in the destination, color 34 becomes 58... I can't find a rule...
Some remarks :
  • Color tables are the same in both files
  • The application is written in native code
  • We use MicroStation V8 2004 (the project is in a complex structure with interaction with many other tools)
Source and destination workdgn will be opened and processed like this :
// we create the destination
if( mdlWorkDgn_createFile( &pModelRefDest,
chFichierTemp,
DGNFILE_FORMAT_V8,
pModelRefSeed,
SEED_CopyDefaultData,
NULL,
NULL,
bThreeD ) != SUCCESS )
// we open the source file
if( mdlWorkDgn_openFile( &pModelRefSource, NULL, NULL, chTempFilename, NULL, TRUE ) == SUCCESS )
CopyContextP  pCC = mdlCopyContext_create(); // a copycontext is created
// we have here a scanner to find elements to copy
// for each element corresponding to the scan criteria, we do:
// element color is correct (pElmdscr->el.hdr.dhdr.symb.color)
if( mdlElmdscr_copy( &pElmdscr, pModelRefSource, pModelRefDest, pCopyContext ) == SUCCESS )
// pElmdscr->el.hdr.dhdr.symb.color is different
mdlWorkDgn_closeFile( pModelRefSource );
mdlCopyContext_free( &pCopyContext ); // copycontext is freed
mdlWorkDgn_closeFile( pModelRefDest );
In the MDL help file, for the function mdlElmdscr_copy, we found this description for the parameter "elDscrPP :
MSElementDescr** elDscrPP IN OUT element descriptor to copy to the destModelRef. It may be modified by this function. The returned value will be the element descriptor as written to the destination.
I agree with the sentence in red for levels or linestyle. For the color I don't know if it applies ?
My question is : Anybody has encountered this kind of issue ? There is a way to solve it ?
Many thanks in advance.
Philippe
