Hey,
I try to implement IStandardsChecker via C#. All seems to work so far, but... when I try to use
void ShowCheckerErrorWithFixOptions( ref MsdStandardsCheckerReplaceChoice HandlingChoice, ref int SelectedFix, string ProblemDescription, string FixesListBoxLabel, ref string[] FixesColumnLabels, ref string[] Fixes, int DefaultFix, MsdStandardsCheckerReplaceOptions ReplaceOptions, bool CurrentlyIgnored, string IgnoredBy = null, DateTime IgnoredWhen = default(DateTime));
I get a "Value does not fall within the expected range." exception. I assume that it has something to do with ref string[] fixes.In C# it should be string[], but VBA documentation says, it should be an array with 2 columns. But when I try to use
var fixes = new string[][] {...}
or
var fixes = new string[ , ] {...}
the compiler complains "Cannot convert ref string[][] to ref string[]" or "...ref string[,] to...".
I have no idea what I should use for that parameter.Could someone please help?
RegardsStephan
