Hi all,
I would like to create a text element for using as a template to create other text elements and I would like the text style to be "none." How would I go about doing this?
Minion
System: Win7 64bit 16GB Ram - microStation V8i SS3 08.11.09.578. + PoinTools CONNECT. - Intel i7-4800MQ CPU@2.70GHz, 4 core / 8 Logic proc.
Anyways, I Oogled on this forum and found these two threads, maybe it is of use to you?:
Changing Text Style of Element
and
Set TextStyle None
/T
Code... We're the good guys now.
