HI
If I change the dialogtext "OptionButton2:" to "Option_ÆØÅæøå:" in the DialogBoxDemo example, the danish characters are not displayed correctly. Please see the attached screendump. I pointed this out in the beginning of august and I was told that a couple of solutions would be provided in the final SDK...
Any ideas ?
TIA, Evan
I haven't gotten to playing with unicode in the mdl dialog boxes yet, but do you have to change the encoding value in the transkit.xml file?
I have gotten a few errors compiling, because I changed some of my defined strings to L"Text" and they were referenced in a dialog item resource as a label. I noticed that the define for the dialog item struct is Utf8Char.
struct DItem_OptionButtonRsc { long synonymsId; UInt32 helpInfo; UInt32 helpSource; long itemHookId; UInt64 itemHookArg; /* The OPTNBTNATTR_... may be used here */ #if defined (resource) Utf8Char label[]; char accessStr[]; // CHAR_OK DItem_OptionButtonItemRsc optionButtonItems[]; #else long labelLength; Utf8Char label[1]; #endif };
I wonder if they need changed to a unicode string after the dialog is loaded using mdlDialog_rItemLabelSet() or one of the mdlDialog_ functions that are available for whichever resource type you're setting. I am pretty sure I have done it this way in the past in v8i just messing around. But I haven't done it in Connect yet.
Rich
