Hey Everyone!
I have an MDL that was made for older versions of Microstation before Connect and I want to build it to work with Microstation Connect. I have downloaded the Microstation Connect SDK and have searched through its documentation as well as online but I haven't found anything stating how this is done exactly. Additionally, I have very little experience with MDLs and I did not make the one I am trying to upgrade so that makes this even tougher for me.
The first thing I have noticed is that the MKE file for my MDL requires .dlo files to be inside of the Library folder but my SDK doesn't contain them. Do I have to build them somehow or is this something that has changed? If I remove mention of these .dlo files and attempt to build it, I am prompted to open the make.opt file for some reason and once I hit cancel on the opening of the file I get a an error saying 'BMAKE: Could not set file time -- check dependencies'.
What exactly am I doing wrong and is there some additional step I should be doing? I basically have just took the old mdl then copy and pasted it then made a few changes to the paths in the make file but I haven't made any other changes.
Here is the command I am using to build it through the Connect SDK CMD:BMAKE -dNO_COMPILERS_MKI -dBUILD_USING_NOTOOLSET "C:\Projects\TestApp-ma\TestApp"
Here is my make file (I have removed some of the comments to shrink it down):
appName = TestAppbaseDir = C:/Projects/TestApp-ma/ms = C:/Progra~1/Bentley/MicroStationCONNECTSDKobjectDir = $(baseDir)objects/mdlLibs = $(ms)/library/privateInc = $(baseDir)langSpec = $(baseDir)libraryExt = ml
#------------------------------------------------------------------------# mdl.mki contains the default rules for creating .rsc, .mo, etc files#------------------------------------------------------------------------%include $(ms)/mki/mdl.mki
#------------------------------------------------------------------------# Define macros for files included in our link and resource merge#------------------------------------------------------------------------bclassObjs = \$(objectDir)$(appName).mo \$(mdlLibs)ditemlib.dlo \$(mdlLibs)rasterlib.dlo \$(baseDir)TestApp.dlo
bclassRscs = \$(objectDir)$(appName)cmd.rsc \$(objectDir)$(appName)typ.rsc \$(objectDir)$(appName).mp
#------------------------------------------------------------------------# Generate command table include & resource file using rcomp#------------------------------------------------------------------------$(baseDir)$(appName)cmd.h : $(baseDir)$(appName)cmd.r
$(objectDir)$(appName)cmd.rsc : $(baseDir)$(appName)cmd.r
#------------------------------------------------------------------------# Create & compile the app's type resource using rsctype & rcomp#------------------------------------------------------------------------$(objectDir)$(appName)typ.r : $(baseDir)$(appName)typ.mt \$(privateInc)$(appName).h
$(objectDir)$(appName)typ.rsc : $(objectDir)$(appName)typ.r
#------------------------------------------------------------------------# Compile the MDL source object file using mcomp#------------------------------------------------------------------------$(objectDir)$(appName).mo : $(baseDir)$(appName).mc \$(baseDir)$(appName).h \$(baseDir)$(appName)cmd.h
#----------------------------------------------------------------------# The following section generates the MDL Program module using # mlink. This module should contain ALL CODE resources and/or # libraries used by the application.#----------------------------------------------------------------------$(objectDir)$(appName).mp : $(bclassObjs)$(msg)> $(objectDir)make.opt-a$@-csoff-s200000$(linkOpts)$(bclassObjs)<$(MlinkCmd) @$(objectDir)make.opt~time
#----------------------------------------------------------------------# The following section generates the MDL Intermediate module using # rlib. This module contains the MDL CODE module and any # non-translatable resource modules.#----------------------------------------------------------------------$(objectDir)$(appName).mi : $(bclassRscs)$(msg)> $(objectDir)make.opt-o$@$(bclassRscs)<$(RLibCmd) @$(objectDir)make.opt~time
%include $(baseDir)$(appName)rsc.mki
I have an MDL that was made for older versions of Microstation before Connect ...
Your bmake file reveals that you build an old-style MDL app. implemented in a .ma file. That's a byte-code binary that runs in MicroStation's MDL interpreter.
For many years (since V8 was introduced in 2001) Bentley Systems have encouraged us to build native apps.. A native app. for MicroStation is written in C or C++ and built as a Windows DLL using the compiler and linker provided by Microsoft Visual Studio.
Despite that encouragement, we have been able to continue to build .ma apps. for versions of MicroStation to V8i. With MicroStation CONNECT the encouragement has been replaced with a requirement: you must build a native-code DLL. The tools to build that are provided by Viz Studio 2013 or later, depending on your version of MicroStation.
In your case, you must convert your implementation code (the .mc files) to C or, preferably, C++ (.cpp) files. There are quite a few other changes you'll need to make, not least that CONNECT is 64-bit. Check with Bentley Systems to find if they are running any developer workshops that would help.
Answer Verified By: rinedge
Significant changes have occurred in MicroStation CONNECT Edition that impact all MicroStation V8i and prior MDL applications. Consider one of the following options to help determine a best path forward for starting points migrating MDL applications:
Hopefully one of the options listed can get you started in the best direction forward.Bob
Unknown said:I'm not sure if it will be worth the time upgrading the old code
This is very important ... and often ignored ... question! ;-)
Both MicroStation is enhanced and workflows plus project requirements have changed over time. So if you have old pure MDL code, it should be discussed not only if to migrate the code or to start from scratch, but also if the application is required or MicroStation CONNECT Edition can solve your requirements using standard customization and available tools.
If to choose C++ or NET is a result of balancing between required functionality and available resources: Despite of DgnPlatform .NET API in CONNECT Edition is far far better than VBA/COM API available in V8i, it doesn't offer the same range of functionality as C++ MicroStationAPI. So sometimes you have to use C++ API simply because a particular functionality cannot be implemented using NET API. On the other hand it's probably easier to find somebody with a knowledge of C# (or VB.NET, but I treat it as worse option personally) than C++ and it's also more complicated to understand and use C++ API.
With regards,
Jan
MicroStation CONNECT Edition Migration Workshop?
Nothing listed.. there are no recorded session either.Is there any SDK training at all? Only in US?
Karsten Evans said:Is there any SDK training at all? Only in US?
BDN staff hosted a developer meeting in London in September 2019. I believe that they plan to hold similar events elsewhere. They held a migration workshop several years ago in London.
Never heard anything about this, maybe I'm not on a list? Should be as I'm a BDN.Was it emailed out to BDN member or just posted in the group?
Don't suppose it was recorded? If so I can't find anything.
Was the migration workshop recorded? Would be nice if someone put together a CONNECT programming course.Like the old CSP beginners and advanced MDL courses.
Karsten Evans said:Never heard anything about this
Well, it was not announced as Migration workshop, but as Summit ... but the information, related to development (and not marketing of new products and managers type of presentation), were (accordingly to published agenda) mostly about the migration.
Karsten Evans said:Was it emailed out to BDN member or just posted in the group?
Yes:
Karsten Evans said:Don't suppose it was recorded? If so I can't find anything.
I think they promised they will do it, but I do not know whether it was realized or not.
Karsten Evans said:Was the migration workshop recorded?
Not the original ones (4 years ago).
The only (still valuable, but a bit outdated) outputs are PowerPoint and PDF installed with MicroStation SDK.
Karsten Evans said:Like the old CSP beginners and advanced MDL courses.
Nothing like these materials are available. Bentley BDN management (which does not exists, because everybody are now "success managers") is not interested in allocation budget and resources to do these things ... which is incredible as BDN (from reasons I do not understand) seemsto be part of Bentley Institute. And who else should be aware of importancy of professional guides and tutorials.
