We have several MDL applications that open a temporary file using mdlSystem_newDesignFile() and we do not want that file name to be added to Connect's recent file list.
In previous version of MicroStation our temporary files would not be added to the file list on the File pull-down menu. So why the change in Connect? Is there a way to disable having a temporary file added to the Recent FIle list?
This temporary file is only loaded when we are processing a work file using the mdlWorkDgn funcitons. When we are done processing the work file we reload the user's design file. The one loaded when we started processing.
Hello Eirin,
I opened my temporary files in No WorkSet and this approach seems can implement your desired. Please test my below code snippet.
#include <Mstn\MdlApi\MSWorkSet.h> void workSetTest() { MSWorkSpaceManagerR wsMan = MSWorkSpaceManager::GetManager(); DgnWorkSetCR ws = wsMan.GetActiveWorkSet(); wsMan.ActivateNoWorkSet(); mdlSystem_newDesignFile(L"C:\\ATemp\\01.dgn"); mdlSystem_newDesignFile(L"C:\\ATemp\\02.dgn"); mdlSystem_newDesignFile(L"C:\\ATemp\\03.dgn"); mdlSystem_newDesignFile(L"C:\\ATemp\\04.dgn"); mdlSystem_newDesignFile(L"C:\\ATemp\\05.dgn"); mdlSystem_newDesignFile(L"C:\\ATemp\\06.dgn"); mdlSystem_newDesignFile(L"C:\\ATemp\\07.dgn"); mdlSystem_newDesignFile(L"C:\\ATemp\\08.dgn"); mdlSystem_newDesignFile(L"C:\\ATemp\\09.dgn"); wsMan.ActivateWorkSet(ws); }
