Quick question; how do you define the level name when using the change elements tool??
My example:
MbeSendCommand "Change Element Extended "
' Set a variable associated with a dialog box
MbeSetAppVariable "CHANGEBY", "tcb->msToolSettings.changeElement.level", 1& <---- this puts a check in the box/ turns on
MbeSetAppVariable "CHANGEBY", "changeElementInfo.currentLevel", "A-Code"& <----- this is the name of the level to change too
MbeSetAppVariable "CHANGEBY", "tcb->msToolSettings.changeElement.color", &
MbeSetAppVariable "CHANGEBY", "changeElementInfo.currentColor", -1& <----- this sets by-level
MbeSetAppVariable "CHANGEBY", "tcb->msToolSettings.changeElement.style", 0& <----this removes the check/ turns off
MbeSetAppVariable "CHANGEBY", "tcb->msToolSettings.changeElement.weight", 1&
MbeSetAppVariable "CHANGEBY", "changeElementInfo.currentWeight", -1&
Is there a programs reference where I can find some of the “extra options” and correct syntax for these command???
Thanks for the help.
