[v8i MDL] api for import element templates via xml
As you may or may not know, you can manually import and export the element templates as an xml file with the element template dialog.
Is there a way to import those xml files via some mdl api call (or any other c++, it doesn't matter)? I recorded a vba macro of the import and export, but sadly no method calls were saved.
best regards,
Parents Reply Children
