When I was trying to play how to use WPF to create a toolbox with VS 2015 Tools for MicroStation CONNECT Edition , I found that I couldn't fix or change the Window size. Glad if someone could provide the comment as following:
namespace MSAddinSample { public partial class Toolbox : UserControl { private static Bentley.MstnPlatformNET.WPF.DockableToolbar currentControl; private static Bentley.ResourceManagement.IMatchLifetime BRI; private Bentley.MstnPlatformNET.AddIn m_addIn; public Toolbox(Bentley.MstnPlatformNET.AddIn addIn) { m_addIn = addIn; InitializeComponent(); } internal static void ShowWindow(Bentley.MstnPlatformNET.AddIn addIn) { if (null != currentControl) { currentControl.Focus(); return; } currentControl = new Bentley.MstnPlatformNET.WPF.DockableToolbar(); currentControl.ResizeMode = System.Windows.ResizeMode.NoResize; currentControl.WindowStyle = System.Windows.WindowStyle.ToolWindow; currentControl.Content = new Toolbox(addIn); currentControl.Attach(BRI, 'control'); currentControl.Show(); //currentControl.WindowContent.CanDockVertically = false; } private void Toolbox_Unloaded(object sender, System.Windows.RoutedEventArgs e) { currentControl = null; } private void Toolbar_SizeChanged(object sender, System.Windows.SizeChangedEventArgs e) { currentControl.Width = 200; currentControl.Height = 30; } }
