I've had a look at the the ReferenceFile C structure, the mdlRefFile_getParameters() function and also the newer DisplayStyleManager C++ class, but I can't seem to find the correct API function to extract the following info:
Is this exposed anywhere in any of the APIs? Or is this another undocumented linkage ID on the reference element?
HI Piers
Have you found any solution for this issue ? I'm looking for a way to set the display style of a reference.
Hi Evan, I never ended up getting it going, but looking at the latest SDK, it looks like you can at least get the Display Style using the DisplayStyleManager API.
--Piers PorterAltiva Software
