Hi all,
We are trying to use the MDL CONNECT migration tool (migrate.bat) to convert some V8i mdls to CONNECT, but it looks the process igore some files.
Does anybody have any tip or idea to solve it? Is there any specific requirement to include the cpp files into the process?
Here is the text I receive in the migration report:
START: Migration remapping
##### PROCESSING STARTED: 28/10/2016 12:07:13,02 INFO: Backing up source code INFO: Starting Batch Remapping of Source File Types: .c .cpp .h .fdf .hpp
##### PROCESSING FILE [1]
COMMAND: C:\Python27\python.exe ARG1: C:\MDLBAS~3\MigrationTools\ApiRemapper.py ARG2: C:\MDLBAS~3\MigrationTools\0811to1000Published.remap ARG3: C:\Fuentes\PRUEBA~1\MIGRAC~1\DWGAPP~1.CPP RESULT: 1 files (21 Kbytes) read - 0 files changed
##### PROCESSING FILE [2]
COMMAND: C:\Python27\python.exe ARG1: C:\MDLBAS~3\MigrationTools\ApiRemapper.py ARG2: C:\MDLBAS~3\MigrationTools\0811to1000Published.remap ARG3: C:\Fuentes\PRUEBA~1\MIGRAC~1\L8000001.cpp RESULT: 0 files (0 Kbytes) read - 0 files changed
##### PROCESSING FILE [3]
COMMAND: C:\Python27\python.exe ARG1: C:\MDLBAS~3\MigrationTools\ApiRemapper.py ARG2: C:\MDLBAS~3\MigrationTools\0811to1000Published.remap ARG3: C:\Fuentes\PRUEBA~1\MIGRAC~1\T8010002.cpp RESULT: 0 files (0 Kbytes) read - 0 files changed
##### PROCESSING FINISHED: 28/10/2016 12:07:15,66
Start Time: 28/10/2016 12:07:13,02 Finish Time: 28/10/2016 12:07:15,66
IDENTIFIED: [3] Valid source code files extensions for processing: .c .cpp .h .fdf .hpp
MODIFIED FILES:
FINISH: Migration remapping
Thanks in advance,
Eduardo
Hi Eduardo,
Migrating MicroStation V8 code to MicroStation CONNECT (v10) presents a number of choices to make and coding advancements and opportunities to be leverage. The product itself is 64-bit, is extremely customizable with delivered tools, presents many new and improved features and workflows, and programming options (native code C++ and C MDL applications, .NET managed add-ins, MicroStation VBA/COM, MicroStation Basic Recorder "MBR") to name a few. With all these choices it is recommended to become familiar with what the new product currently offers (features, workflows, utilities) and determine if prior custom code is required or is in need to adapt to any new design and workflow changes. At this point possibly consider performing a staged migration of required code; e.g. first 1 to 1 migration (function to method remap), or preferred - explore and use new and powerful API classes (native C++ or managed .NET add-ins), or consider leveraging simpler and very productive and effective task oriented options like: MicroStation VBA or MBR.
Thank you for providing the above output logging details since it provides information on configuration and processing performed.
The purpose of MigrationTools (migrate.bat) is to provide developers a way to perform 1 to 1 "old function or type" to "new static method or property" replacements. Though there are approximately 2500 such search and replacement remap entries, this approach only helps achieve a minimal amount of migration efforts required in a semi-automated manner.
For any migration topics or specific function recommendations I highly encourage you to first search the MicroStation Programming forum (via search text box at the top middle section of any page) then ask/post your questions. You should find the developers on the Bentley Programming Forums to be very helpful in helping you make prompt and correct choices moving forward and helping solve most issues presented.
HTH,Bob
Answer Verified By: Eduardo Cortes
