Hi ,
Anybody knows how to get the begin and end point of a curve and a arc ????
Thanks for your help !!
Both Arcs and Curves have StartPoint and EndPoint properties (in VBA), that you can access similar to:
Dim oArcElement As ArcElement Set oArcElement = Element With oArcElement dPrimaryRadius = .PrimaryRadius dSecondaryRadius = .SecondaryRadius dSweepAngle = .sweepAngle dStartAngle = .StartAngle rotationMatrix = .Rotation CenterPnt = .CenterPoint StartPnt = .StartPoint EndPnt = .EndPoint End With
HTH,Bob
Answer Verified By: Xavi García Maranges
Please follow the MicroStation Programming forum best practices.
Please identify the version of MicroStation, or other product such as PowerDraft, that you are using: MicroStation CONNECT or MicroStation V8i. What is the 8-digit version number (e.g. 10.xx.yy.zz) of MicroStation?
If you're using MicroStation in a ProjectWise (PW) managed environment, let us know that too.
The APIs supplied with MicroStation CONNECT are different to those supplied with MicroStation V8i. Consequently, our answers are likely to be different.
Are you writing MDL, C++, C#, VB.NET or MicroStation VBA?
When you post code, use the Forum advanced editor's syntax highlighting tool. That's the icon that resembles a pencil:
Both ArcElement and CurveElement implement VBA's ChainableElement interface. Use the .AsChainableElement method, then the StartPoint and EndPoint properties. It's all documented in VBA help.
