Hello, I have a table with MSLINK data, I query my table by using mdlDB_openCursorWithID(CursorId, query) and loop through my data I use mdlDB_processSQL(insert statement) to insert rows into my table. The first insert works fine, but upon the next fetch, the mdlDB_fetchRowByID returns the status of -100. If I comment out my mdlDB_processSQL(insert statement) the cursor again queries through the complete table again.
is it not possible to use the mdlDB_processSQL function within a cursor loop? If not, what would be the alternate method? If so, why would this be erroring? I can cut and paste the insert statement and manually I'm successful with entering the data.
Thanks in advance,
John Schenk
Hi John,
I have no answer for the discussed problem, but my guess some more information may be required:
... the communication between MicroStation and database is a long chain, so it may be helpful to know exactly what pieces of software are involved.
Just an idea: Is it possible to try the same code with another database or the same database but different driver?
With regards,
Jan
John,
Please try the steps listed in order from this post: mdlDB_fetchRowByID and let us know if that helps resolve the issue. If not, here is another search for a couple other threads ( 8 ) related to calling mdlDB_fetchRowByID and needing to enable/disable autocommit accordingly.
HTH,Bob
Answer Verified By: John Schenk
Same for me, thank you for posting. This saved me several hours of work.
Thanks Bob, this is the solution!
If you use mdlDB_processSQL() (Update/Insert SQL statements) within mdlDB_openCursorWithID()/mdlDB_fetchRowByID() loop you must turn off auto commit before. Otherwise (auto commit is TRUE by default) you get CURSOR_NOT_OPEN (4075) error code on next (second) mdlDB_fetchRowByID() function because it closes CursorID immediately after mdlDB_processSQL().
Here is an example for Access database.
MS_sqlda sqlda; CursorID cursorID; char sql[1000], sql2[1000]; // lines marked with [*] makes the trick status = mdlDB_activeAutoCommitMode(FALSE); // turn off auto commit [*] if ((status = mdlDB_openCursorWithID(&cursorID, sql)) == SUCCESS) { while ((status = mdlDB_fetchRowByID(&sqlda, cursorID)) == QUERY_NOT_FINISHED) { // process sqlda.value[0] etc. mdlDB_processSQL(sql2); // insert / update SQL statements } mdlDB_closeCursorByID(cursorID); mdlDB_freeSQLDADescriptor(&sqlda); } // Below lines are moved to outside if condition according to Jon's comment below. status = mdlDB_processSQL("COMMIT"); // do a commit [*] status = mdlDB_activeAutoCommitMode(TRUE); // turn on auto commit [*]
Kind regards,
Sedat AlisAEC Technology Inc.
Sedat Alis said: you must turn off auto commit before
This thread is several years old, but since you've resurrected it I'll make this comment.
int status = mdlDB_activeAutoCommitMode(false);
You have to remember to restore the commit mode. However, in procedural code that is often a problem. In your example, the corresponding restore is inside a scope...
if (condition) { ... status = mdlDB_activeAutoCommitMode(true); // turn on auto commit [*] }
If that condition fails, then you will have turned off commit mode but never restored it.
Use a class to wrap the commit/restore function...
Here's the class...
struct DbCommitManager { const bool AutoCommitOn {true}; const bool AutoCommitOff {!AutoCommitOn} DbCommitManager () { mdlDB_activeAutoCommitMode(AutoCommitOff); } ~DbCommitManager () { mdlDB_activeAutoCommitMode(AutoCommitOn); } };
Use couldn't be simpler...
void SomeSqlMethod () { // Your method that wants commit off: class constructor performs that task DbCommitManager commitMgr; if (condition) { // SQL stuff with commit off } // DbCommitManager destructor is called automatically on leaving scope. // Commit is restored whether or not the condition failed }
You can use the same idiom for a number of MDL functions that acquire a resource and must subsequently release it.
Jon Summers said:This thread is several years old, but since you've resurrected it I'll make this comment. int status = mdlDB_activeAutoCommitMode(false); You have to remember to restore the commit mode. However, in procedural code that is often a problem. In your example, the corresponding restore is inside a scope... if (condition) { ... status = mdlDB_activeAutoCommitMode(true); // turn on auto commit [*] } If that condition fails, then you will have turned off commit mode but never restored it.
You are absolutely right! Turning on auto commit mode within if condition will be a problem. Thank you for the fix. I have fixed the code for anyone copying the code before seeing your comment.
