[Connect API] Attach reference reprojected
In V8i you could something like this to attach a reference reprojected:
mdlRefFile_setParameters ((void *) ATTACHMETHOD_GeographicProjected, REFERENCE_ATTACHMETHOD, ModelRef);
I want to do the same in Connect:
mdlRefFile_setIntegerParameters(ATTACHMETHOD_GeographicProjected, REFERENCE_ATTACHMETHOD, ModelRef);
The problem is that the enum value "ATTACHMETHOD_GeographicProjected" can't be found in the headerfiles.
I've made a small workaround:
#ifndef ATTACHMETHOD_GeographicProjected
#define ATTACHMETHOD_GeographicProjected 31
#endif
This will work but I think that the headerfiles should be updated to include the enum values.
Regards, Evan
