I'm working on a macro which consists of a userform which does the following:
So far I have been successful and can access the data in the array however I have hit a stumbling block. This is the first time I've used IPrimitiveCommandEvents and the remaining steps I am trying to achieve are:
Currently I can place a single piece of text but its location appears to be offset and placed at the end of the loop (i.e. number of rows in array multiplied by spacing between text elements) instead of placing one element, move position, place the next element from the array. Here is some of the code relevant to the operation:
Private Sub IPrimitiveCommandEvents_DataPoint(Point As Point3d, ByVal View As View) Dim oText As Element Set oText = TextFromArray(Point) oText.Redraw msdDrawingModeNormal ActiveModelReference.AddElement oText End Sub Private Function TextFromArray(Point As Point3d) As Element Dim C As Long Dim i As Integer Dim el As Element Dim DataPoint As Point3d Dim R As Long Dim sHorizOffset As Point3d DataPoint = Point 'remember the original data point coordinates i = 1 sHorizOffset = Point3dFromXYZ(5, 0, 0) Point = Point3dAdd(Point, Point3dFromXYZ(13.5, 52.25, 0)) 'set the offset from the data point for the chainage column For i = 1 To lNumRows Debug.Print "i=" & i Set el = CreateTextElement1(Nothing, CStr(ArrayData(1, i)), Point, Matrix3dIdentity) Set TextFromArray = el 'i = i + 1 Point = Point3dAdd(Point, sHorizOffset) Next i End Function
It's not finished as I've yet to add lines to deal with the other columns in the array, I'm simply trying to achieve the creation of individual text elements from the 1st column in the array.
Any suggestions welcome
Unknown said: I can place a single piece of text but its location appears to be offset and placed at the end of the loop
That's what you've told MicroStation to do. If we scrape away the useful stuff to see what your TextFromArray is doing...
That statement can only ever create one piece of text. Your method iterates a loop before returning that text. Each time it loops, it creates a text element that is subsequently discarded except for the loop's final iteration...
Private Function TextFromArray(Point As Point3d) As Element ... For i = 1 To lNumRows Set el = CreateTextElement1(Nothing, CStr(ArrayData(1, i)), Point, Matrix3dIdentity) Set TextFromArray = el Next i End Function
Rather than return the text element, simply add it to the active model inside your loop.
Once you have all that working, read this article about transactions in MicroStation VBA.
You don't have to write code! Use FlexiTable, which already knows how to read an Excel worksheet and turn it into a table in MicroStation.
Thanks Jon,
I wasn't sure if multiple elements could be created in memory and then all added to the activemodel at the end of the loop. I've added your suggestion and the text creation now works as I was hoping.
I'm now in the process of amending my TextFromArray function so that I'm not just supplying the datapoint from IPrimitiveCommandEvents_DataPoint event, I also want to supply an array and a point3d offset string from the datapoint to make the function reusable for all the arrays and offsets I will be working with. I'm able to create the text elements from the first array however the data from next array is not creating, it does contain data so I'm unsure if its due to not being able to call the TextFromArray function multiple times in the _DataPoint event. It appears that the function exists after the first array completes its loop instead of returning back to the _DataPoint event as I thought it would.
Private Function TextFromArray(Point As Point3d, ByRef data() As Variant, ByVal sDataPointOffset As String) As Element Dim C As Long Dim i As Integer Dim el As Element Dim DataPoint As Point3d Dim R As Long Dim sHorizOffset As Point3d Dim sOffsetArray() As String DataPoint = Point 'remember the original data point coordinates i = 1 sHorizOffset = Point3dFromXYZ(5, 0, 0) sOffsetArray() = Split(sDataPointOffset, ",", , vbTextCompare) Point = Point3dAdd(Point, Point3dFromXYZ(sOffsetArray(0), sOffsetArray(1), sOffsetArray(2))) 'set the offset from the data point for the chainage column For i = 1 To lNumRows Debug.Print "i=" & i Set el = CreateTextElement1(Nothing, CStr(data(i, 1)), Point, Matrix3dIdentity) Set TextFromArray = el el.Redraw msdDrawingModeNormal ActiveModelReference.AddElement el Point = Point3dAdd(Point, sHorizOffset) Next i Debug.Print "Completed first Array" Point = DataPoint ' Reset Point back to original data point location End Function Private Sub IPrimitiveCommandEvents_DataPoint(Point As Point3d, ByVal View As View) Dim oText_Chainage As Element Dim oText_Ex_Levels As Element Set oText_Chainage = TextFromArray(Point, ArrayChainage, "13.5,52.5,0") Set oText_Ex_Levels = TextFromArray(Point, ArrayUpTrack, "13.5,49.75,0") End Sub
