Using the MicroStation SDK with Power InRoads.
My company has recently changed from MicroStation to Power InRoads.  Both SS2 and SS4 varieties have been installed.  Is it possible to use the MicroStation SDK to access the MicroStation functions of Power InRoads?  Is it as simple as just changing the Install path for the SDK?  It doesn't seem correct to install it twice to use on both SS2 and SS4.  I am not sure if I can switch between the versions even if I do install the SDK twice or just once for that matter.  I would think that the environment settings would reflect the second install only.
Jason
