[CONNECT C++] App. not unloading - prevents build
I've recently come across a problem that I've not encountered previously.  During development, it's commonplace to build an app., load into MicroStation, perform some tests, unload the app. and make some changes.
I unload my app. (*.ma + *.dll), make some modification to the source, and rebuild.  The build fails to complete, with this message...
MicroStation Resource Librarian 03.09.02
### Cannot write to output file: G:\PROGRA~1\Bentley\MICROS~2\MICROS~1\mdlapps\xxxx.ma
Note that it's the .ma file that is apparently locked by MicroStation, not the DLL.  I double-check that the app. really is unloaded (in the Utilities|MDL Apps dialog) but have the same problem.  The build completes only if I exit and restart MicroStation.  As you'll appreciate, this is a little tedious — it gives C++ developers the same pain that .NET developers experience.
