[VBA] Activate a dgnlib textstyle
How to activate textstyle programmatically(like after key-in:textstyle active "Tahoma_03_LT") which is from attached library(TextStyle.IsFromLibrary )?
   Dim txsp As TextStyle
Set txst = ActiveDesignFile.TextStyles.Add(Nothing, "Tahoma_03_LT")
        Set txst = ActiveDesignFile.TextStyles.Find("Tahoma_03_LT")
txsp.UsesColor = False
This gives "unknown error". If comment out "Set txst = ActiveDesignFile.TextStyles.Add(Nothing, "Tahoma_03_LT")" then I get "run-time error 2147221504 (80040000):  The TextStyle is locked and cannot be modified." which is not a surprise as  textstyle in dgnlib can't be modified. I need to change usescolor flag as workaround to Defect 668134.
  • Thanks I have read the article but in this case I not only need to know if it is in active file or not but also to copy it from dgnlib to active file so it is "activated".
  • Modify the function in the article I cited.  The existing MDL function gets a C pointer to the text style.  The following MDL function adds a new text style to the active DGN file...
    Declare Function mdlTextStyle_addToFile Lib "stdmdlbltin.dll" ( _
      ByRef pNewTableEntryId As Long , _
      ByVal pStyle As Long , _
      ByVal pStyleName As Long , _
      ByVal bLockEntry As Long ) As Long
    The second argument, pStyle, is the pointer styleAddress you got from the first MDL function.  Here's what the complete function might look like (untested code)...
    Public Function AddTextStyle(ByVal name As String, ByVal searchLibs As Boolean) As Boolean
    AddTextStyle = False Dim styleAddress As Long Dim styleIdAddress As Long styleIdAddress = -1 If (SUCCESS = mdlTextStyle_getByName( _ styleAddress, styleIdAddress, StrPtr(name), _ ActiveModelReference.MdlModelRefP, searchLibs)) Then Dim newId As Long Const LockEntry As Long = 0 ' No idea what that does! AddTextStyle = (SUCCESS = mdlTextStyle_addToFile ( _ newId, styleAddress, name, LockEntry) End Function
    Regards, Jon Summers
    LA Solutions
    FYI.  This was used in MicroStation V8 to get/set the locked flag in the element header.
  • Unknown said:
    #If VBA7 Then
    Private Declare PtrSafe Function mdlTextStyle_addToFile Lib "stdmdlbltin.dll" ( _
      ByRef pNewTableEntryId As Long, _
      ByVal pStyle As Long, _
      ByVal pStyleName As LongPtr, _
      ByVal bLockEntry As Long) As Long
    Private Declare PtrSafe Function mdlTextStyle_getByName Lib "stdmdlbltin.dll" ( _
        ByRef pStyle As Long, _
        ByRef pTextStyleId As Long, _
        ByVal modelRef As LongPtr, _
        ByVal SearchLibrary As Long) As Long
    #Else
      ByVal pStyleName As Long, _
    Declare Function mdlTextStyle_getByName Lib "stdmdlbltin.dll" ( _
        ByVal modelRef As Long, _
    #End If
    Some minor typos but function works almost as expected
       styleIdAddress = -1
          Dim newId                           As Long
          AddTextStyle = (SUCCESS = mdlTextStyle_addToFile( _
            newId, styleAddress, StrPtr(name), LockEntry))
            End If
    End Function
    Only issue that style is copied not activated from dgnlib so "Update from library" option is greyed out. Does the LockEntry sets that it is linked from library?
  • And how to remove this lock flag if it is set? The keyin "textstyle unlock [textstyle_name]" doesn't apply to MS V8i >SS3.  Returns "Unknown key-in or command."
    And how to set flag that style is copied from library?
Reply Children
  • There seems to be issue in CONNECT edition that after modifying (or activating) a textstyle, the new properties are not available in VBA object ActiveDesignFile.TextStyles in the current session - this is addresses with Defect 588953 and scheduled in MS Update 6 to be fixed.
    Also textstyle object has no method to activate, alternative is to use the keyin to activate the textstyle to keep the library link and allow to modify textstyle properties.
    Dim sTS As String
    sTS = "Tahoma_03_LT"
    CadInputQueue.SendCommand "textstyle active " + sTS
    Unfortunately the Defect 588953 does not allow to modify the textstyle directly after activating the textstyle, as the textstyles are not refreshed automatically during the session.
