Good day all,
I have a peculiar problem with my custom line-styles. I do a lot of electrical reticulation work, and with that we have custom line styles we use for representing different cables in our drawings.
1. 35-B conductor. This is a cable showing the phase of the line, it is B, which can be any one of R,W or B.
It clearly shows the custom line has the text aligned to the length of the line.
2. The issue i have is with line-style number 35-W.
As the image below will show you, the text is always horizontal, unlike the picture above.
Is there a way i can fix this.
Thank you. I have attached the .rsc resource file here.ElecLines.rsc
Unknown said:I have a peculiar problem with my custom line-styles
Is this a programming question? You might be better off posting to the MicroStation Forum.
