How to use codes to open the AcccuDraw
I inherited the class of DgnPrimitiveTool ,  my aim is to use this tool class to draw a line,
in the mouse click event - _OnDataButton , write the codes.
first:  how to open the AccuDraw use codes , when I draw the line , both  before and  after I click the mouse ,I need the AccuDraw to take effect  .
second: how to use the  AccuDraw to set direction , example lock x axis.
supplements: we can open the AccuDraw by shortcut F11 and O
Parents Reply Children
  • Unknown said:
    I want to know how to use codes to open AccuDraw
    There is an AccuDraw example delivered with the MicroStation CONNECT SDK...
    ..\SDK\examples\Elements\AccuDrawDemo
    Unknown said:
    Development language is MDL
    The MicroStation CONNECT SDK provides the MicroStationAPI C++ interface.  While some MDL functions remain, the API is mostly C++ classes.
    For example, if you search MicroStationAPI help you will find classes for both AccuDraw and AccuSnap.
    Regards, Jon Summers
    LA Solutions
