Upgraded to the latest SDK for Update 5
I have installed VS 2015 since that is now required..now I am having a hell of a time getting the bentley compiler to recognize files like windows.h and winsock.h
fatal error C1083: Cannot open include file: 'windows.h': No such file or directory
do I need to include the windows SDK paths in my make file?
Any help would be greatly appreciated!
Hi Maury, I presume this is based on where the shell/tools believe VS2015 is located. From a developer shell, type: "set vs".Are the path values correct, incorrect, or empty? Alternately, from the developer shell you could try to confirm if the VS environment script is being resolved and called correctly by typing: "where vcvars32.bat"; which we call and should configure VS tools environment properly.
Lastly, if these compilation errors are coming from the developer shell, what color is the text within the developer shell (white or yellow)? White is administrative user (and as will all tools called), Yellow is standard user (not likely to have all necessary permissions required).
Bob
Hi Bob,
Thanks for the response.
The paths all look good.. I tried both with and without admin priv. In either case it cannot locate the header files.
By manually adding the windows sdk directories in to the MKE file, the compiler is locating the headers fine, but now i am running into similar issues with locating lib files.
C:\PROGRA~1\Bentley\MICROS~2\examples>set vs VS110COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\Tools\ VS120COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\Tools\ VS140COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\Tools\ VS90COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\Tools\ VSDIR=C:\PROGRA~2\MICROS~4.0\ VSDIRS=VSDIR VCBIN VCINC VCLIB VSINSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio 14.0\ C:\PROGRA~1\Bentley\MICROS~2\examples>where vcvars32.bat C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\vcvars32.bat
My windows.h is being resolved from:
C:\Program Files (x86)\Windows Kits\10\Include\10.0.14393.0\um\Windows.h
Though surprising to me, newer versions of Microsoft Visual Studio actually require you to check/install additional components to provide a fully functional C++ build environment. The most important non-default I know of to this point is needing to check the "Visual C++" option for a developer install. Puzzling. :)
I likely have checked additional items too since I work across a variety of different project types. I will check to see if I can determine what Visual Studio 2015(+) installer options may need to be checked to ensure windows headers, libraries, etc. are also present. I do know these/my items are installed as part of: Windows SDK Desktop Tools "Windows SDK Desktop Headers Libs Metadata" components.
UPDATE: This Microsoft post may be a/our starting point to understand the new install requirements for Visual C++ developer environments
Setup Changes in Visual Studio 2015 Affecting C++ Developers.
I will need to look further into this so I can determine if we should proactively publish a new "Additional Recommendations" clause to our exiting Microsoft Visual Studio Requirements help topic.
Unknown said: newer versions of Microsoft Visual Studio actually require you to check/install additional components to provide a fully functional C++ build environment. The most important non-default I know of to this point is needing to check the "Visual C++" option for a developer install
I'm sure you're not the only one puzzled by Viz Studio installation. As well as that option, have I interpreted correctly that one also needs the Windows XP option to obtain the platform SDK?
Unknown said:I will need to look further into this so I can determine if we should proactively publish a new "Additional Recommendations" clause to our exiting Microsoft Visual Studio Requirements help topic
We'll be grateful for that!
Bob, Thanks for taking the time! It is much appreciated. I already have the entire Universal windows app development section checked in my install. The problem is not with my files missing, I have the exact file in the same folder as you do. If I make a normal console application through visual studio, it will find it and compile fine.
BMake finds the cl.exe in the visual studio VC directory and starts compiling so the environment is at least partially working, it is just having issues locating the headers and libs.
