[MICROSTATION V8i SQLITE ODBC]
I 'm trying to connect MicroStation to SQLITE  by ODBC, but MicroStation don't see the table
Parents Reply
  • Can you confirm if your is Access 32-bit or 64-bit, and if you created a 32-bit ODBC data source connection for MicroStation V8i?
    MicroStation V8i is 32-bit and requires a 32-bit registered ODBC connection via the 32-bit (2nd listed) ODBC data source manager:
    C:\Windows\System32\odbcad32.exe (For 64-bit application connections)
    C:\Windows\SysWOW64\odbcad32.exe (For 32-bit application connections)
    MicroStation CONNECT Edition is 64-bit and would require registering your ODBC connection via the 1st ODBC data source manager.
    Please note in both cases above, you would need to download and install a respective 3rd party ODBC driver if the connection target is not one Windows supports natively
    HTH,
    Bob
    Answer Verified By: Roberta Franceschetti
