[CE5 C#] DimStyleProp Alignment Problem
In VBA, to set the Alignment mode in DimensionStyle from "View" to "True", we use
DimensionStyle.Alignment = MsdDimAlignment.True
When we are in .NET API, we use:
DimensionStyle.SetIntegerProp(2, DimStyleProp.General_Alignment_INTEGER);
and apply it to DimensionCreateData.
However, the dimension element is not working as true alignment. What did I miss?
    did you try to replace the modified DimensionStyle in the dgn file using something like this:
    DimensionStyle.Replace(null,null);
    Please let us know if this helps.
    Best regards,
    Artur
  • Dear Artur,
    Yes, I have tried your suggestion but it was not working. After many trial & error, I found that if I move the dimension element in CE5, it will change back to correct shape, but a different(wrong) shape in V8i.
    The Left was the preferred shape and the Right one was the incorrect shape generated by .NET API.
    I attached the dgn for your reference.
    dgn.zip
  • Hi,
    thank you for providing the DGN example. From what I can see the position of handle1 seems to be off the correct position:
    Without knowing the code example used to create this dimension it is difficult to say what needs to be changed to obtain a better result.
    The "Fit Options" settings has influence in positioning the dimension text/terminator, do you get different results disabling fit:
    It would be great if could upload a testcase containing you source code which created this dimension element.
    For reference I have posted here a code example with title: "Create dimension element with true Alignment"
    Best regards,
    Artur
  • What I meant in last post was to use "move element" tool to move the dimension element, but not moving the handle of dimension element.
    You will finally see a correct shape in CE5 and incorrect shape in V8i.
    Thank you for your code example, compared with your example and I found that I didn't use:
    DTransform3d dtrans = new DTransform3d(dmat);
    TransformInfo transform = new TransformInfo(dtrans);
    dimElement.ApplyTransform(transform);
    On the other hand, I used this method to replace ApplyTransform
    dimElement.SetRotationMatrix(dmat);
    But SetRotationMatrix did not work as expected and generated a strange dimension element.
    I can see the different behavior with moving the element (not handle) between V8i and CONNECT. I just noticed the position of the handle before moving the element, and that´s not where I would expect it.
    But the resulting dimension element does not allow to determine what exactly caused the creation of this element without knowing the source code.
    Providing a test case containing the source code could help to understand this issue.
    Artur
    //<----Dimension--->
                DgnFile dgnFile = Session.Instance.GetActiveDgnFile();
                DgnModel dgnModel = Session.Instance.GetActiveDgnModel();
                DimensionStyle oDimStyle = DimensionStyle.GetSettings(dgnFile);
                DgnTextStyle txtStyle = DgnTextStyle.GetSettings(dgnFile);
                LevelHandle levelHandle = dgnFile.GetLevelCache().GetLevelByName('Default');
                Symbology symb = new Symbology();
                DirectionFormatter dirFormatter = new DirectionFormatter(dgnModel);
                oDimStyle.SetIntegerProp(2, DimStyleProp.General_Alignment_INTEGER);
                oDimStyle.SetBooleanProp(true, DimStyleProp.ExtensionLine_ShowAny_BOOLINT);
                oDimStyle.Replace(null, null);
                DimensionCreateData DimensionCreateData = new DimensionCreateData(oDimStyle, txtStyle, symb, levelHandle.LevelId, dirFormatter);
                DimensionElement dimEle = new DimensionElement(dgnModel, DimensionCreateData, DimensionType.SizeArrow);
                //Set Rotation
                double a = Math.Atan2(Converts.ToUOR(1000), Converts.ToUOR(1000));
                DMatrix3d oMatrix = new DMatrix3d(Math.Cos(a), Math.Sin(a), 0, Math.Sin(a), Math.Cos(a), 0, 0, 0, 1);
                dimEle.SetRotationMatrix(oMatrix);
                //Set dimension Points
                dimEle.InsertPoint(calc.TranslateD(0, 0, 0), null, oDimStyle, 0);
                dimEle.InsertPoint(calc.TranslateD(Converts.ToUOR(1000), Converts.ToUOR(1000), 0), null, oDimStyle, 1);
                dimEle.SetHeight(Converts.ToUOR(500));
                dimEle.ApplyDimensionStyle(oDimStyle, true);
                dimEle.AddToModel();
    As I have not solved how to get the active dimension style's parameters (when no external dimension style created), with these code and a new dgn file you may generate a error dimension element with error parameter.
    or like this
    Just use the previously uploaded dgn to prevent this kind of unknown errors.
Reply
                //Set Rotation
    or like this
