My system is windows 7, VS 2013, VS 2015, NO clr support
I get same 11 errors, VS2013 and VS 2015 when including PointCloudApi.h
Same errors has occurred in update 1,2,3 and 4
Error list:
Error 9 error C2039: 'OrientedBoxCR' : is not a member of 'Bentley::DgnPlatform' Error 12 error C2039: 'OrientedBoxCR' : is not a member of 'Bentley::DgnPlatform' Error 14 error C2061: syntax error : identifier 'IPointCloudChannelVectorCR' Error 10 error C2061: syntax error : identifier 'OrientedBoxCR'Error 13 error C2061: syntax error : identifier 'OrientedBoxCR' Error 11 error C2061: syntax error : identifier 'PointCloudChannelId' Error 6 error C2061: syntax error : identifier 'PointCloudPropertiesCR' Error 8 error C2065: 'Xyz' : undeclared identifier Error 15 error C2535: 'Bentley::IPointCloudQueryBuffersPtr Bentley::PointCloud::IPointCloudDataQuery::CreateBuffers(UInt32,UInt32)' : member function already defined or declared Error 7 error C2653: 'PointCloudChannelId' : is not a class or namespace name 18 IntelliSense: cannot open source file "_config-eccp.h"
Any suggestions?
thanks
Nenad
Did you try to analyse header files? Your error list does not provide enough information, because it's not clear in what header file(s) the errors arised. PointCloudApi.h is an "entry point" only that includes other header files.
Also, did you try to include PointCloudClipHandler.h? As I wrote and Jon confirmed, OrientedBoxCR is defined in this header. Did you check the header file is properly included in the place where error is reported? The header file seems fine to me, but to have and use some testing code is always better.
Unknown said:I get same 11 errors, VS2013 and VS 2015 when including PointCloudApi.h
Why do you mention VS2013 when reporting error for Update 5? It's a bit confusing and not relevant for the reported problem, because only VS2015 is supported by update 5 SDK.
Unknown said:Any suggestions?
Ask in a better way. For example I found out in this post Artur confirmed the bug was reproduced and logged as Defect # 641666. Why you don't ask directly whether Defect # 641666 has been solved in Update 5 SDK?
With regards,
Jan
"Did you try to analyse header files?"
Yes I did. As I wrote, errors have occurred in all updates and I have tried and analyzed everything I could think off.
"Also, did you try to include PointCloudClipHandler.h? "
Yes, I did and as result I got not 11 but 24 errors.
"Why do you mention VS2013 when reporting error for Update 5? It's a bit confusing and not relevant for the reported problem, because only VS2015 is supported by update 5 SDK."
"Ask in a better way. For example I found out in this post Artur confirmed the bug was reproduced and logged as Defect # 641666. Why you don't ask directly whether Defect # 641666 has been solved in Update 5 SDK?"
I did ask in my post if anybody have list/link of fixed issues in SDK for Connect update 5 (10050040).
But even with that list and answer from Artur , how can I be sure that this is not a new bug? Or maybe Defect # 641666 is just partially fixed?
the Defect #64166 is not yet fixed with Update 5.
The error messages related to "OrientedBoxCR" could be caused by including PointCloudClipHandler.h, but without including previous DgnPlatformAPI.h.
Could you please give us an overview about your inlcuded Headerfiles and the order they are included?
Artur
Hi Artur,
Just to be clear, I am using sdk update 5 and VS 2015
Overview about my inlcuded Headerfiles and the order they are included.
#include <Mstn\MdlApi\MdlApi.h>#include <PointCloud\PointCloudApi.h>#include <DgnPlatform\DgnPlatformApi.h>#include <DgnPlatform\PointCloudClipHandler.h>
thanks for your help
Hi Nenad,
Unknown said:nd the order they are included.
Did you try to include PointCloudClipHandler.h before PointCloudApi.h?
From your screen capture posted earlier it's visible that the first error with missing OrientedBoxCR is reported in PointCloudEdit.h. This header file is included in PointCloudApi.h, but OrientedBoxCR is defined in PointCloudClipHandler.h, which is included later. So even in the case the definition is correct, it's not known to compiler in the time when PointCloudApi.h is included.
Hi Jan
yes I did try and errors with OrientedBoxCR er gone but I have 21 errors know, mostly in PointCloudClipHandler.h
Has anybody managed to include PointCloudApi.h without getting errors? If so, can a sample code be provided?
At I would know than that I am doing something wrong
Unknown said:At I would know than that I am doing something wrong
I have not enough time to test it, but it seems more like wrong dependency between headers and in such case it has solved by Bentley.
I can imagine as a temporary solution you can use existing definition of OrinetedBoxCR and move it to e.g. PointCloudApi.h, but it will not solve all reported errors.
regarding the include order I would recommend to include DgnPlatformApi.h before including any PointCloud related Header file.
The include order I see here is:
DgnPlatformApi.h is includingDgnHandlersAPI.h is includingPointCloudHandler.h is includingPointCloudClipHandler.h, which has typedef OrientedBox
Best regards,Artur
Answer Verified By: Nenad Poljcic
Your solution works! No error messages.
Thank You for your time.
