How do I activate existing DgnModel using NET API c# ?
thanks
Nenad
Hi Nenad,
Unknown said:How do I activate existing DgnModel using NET API c# ?
There is an open Enhancement Request # 432451 for a .NET method to activate a loaded model.
Known workarounds are to import the mdl API function mdlModelRef_activateAndDisplay or the COM API method Activedesignfile.Models(modelName).Activate
Best regards,Artur
Answer Verified By: Nenad Poljcic
Only Activate Model , Not Display it, How to do?
Hi xinghu,
Unknown said:Only Activate Model , Not Display it, How to do?
I am not quite sure whether I understand your question right, because in MicroStation "to activate model" (open particular model by user) means "to display it".
Can you explain what do you want to achieve?
Jan
