As in other GIS based Platforms, If we draw a polygon overlapping on other polygon while digitizing an area, we automatically get two different polygon with a common edge without any overlap area. Can we do the same in Bentley Map as it is also enable us to create a Geo-spatial Database?
Unknown said:If we draw a polygon overlapping on other polygon
You've posted to the Programming Forum, but this seems to be a question about using Bentley Map. Why not post your question to the Bentley Map Forum?
Ok.. Thanks for the suggestion, though.
