When plotting a cell through the Bentley Cell window, If the cell that has annotation, I can plot that cell by unchecking "Place as Shared Cell" and a "Annotation Cell" element is created.
If I plot the same cell with the "Place as Shared Cell" option enabled, a "Shared Cell Element" is created.
If I plot a cell that does not have any annotation and have "Place as Shared Cell" unchecked, a "Cell" element is created.
For a SharedCellElement, I can call the "AddAnnotationScale" method and it will scale to the design file drawing scale properly.
CellHeaderElement does not have this method, the only thing I could do is scale the CellHeaderElement by the annotation scale, but this would not react to changes in the design file drawing scale.
When Bentley creates an "Annotation Cell" it reacts properly to the drawing scale, but I do not know how to create this element type.
CellHeaderElement has a getter for "IsAnnotation" property, but no setter.
How does one make an "Annotation Cell" using the DgnPlatformNet API?
Maury
A cell is a model. A model has properties. For some reason they are obtained via the ModelInfo struct rather than model properties. In the MicroStationAPI this is in the ModelInfo Struct Reference. ..
void SetIsAnnotationCell (bool isAnnotationCell)
That's mirrored in the DgnPlatformNet documentation.
Hi Jon,
Not seeing that method in my documentation though I have not updated to U6.
Either way, the cell may be stored as a model in the cell library, but once its plotted it becomes a CellHeaderElement and no longer has its own Model\ModelInfo.
If I am wrong and it is still a model, I have no idea how to reference it. The DgnModel property points to the model that it was drawn in.
