My thoughts and fears on using text styles in Border-Seed-Files.
I have a bad feeling regarding text styles and its application on Border-Seed-Files.
As an example, the following configuration:
- In a DGN.lib I have all my text styles and are available ion every drawings.
- I have created new Border-Seed-Files with these text styles and the used styles are now integrated as a local style in the Border-Seed-File (recognizable by the blue tick in the text style window).
So far everything is ok.
But now my thoughts and fears ....
If somebody later changes and saves one of the used text styles, all texts in this drawing will be adjusted accordingly.
This would lead to texts from the Border being changed unintentionally!?
So my question is, does it make sense to work in a Border-Seed-File with text styles or should it be better to put all the texts on text style "none" at the end just before releasing them?
I hope I could explain my fears and would be glad if you could tell me your personal opinions and how you are working on that.
Many Thanks
Raphael
