There is build error about bmake. It reports the setdefaults function can't be found.
I found in bsimaterial.h as following P_SetDefaults. But I can't find any SetDefaults. Is there anything I miss. /*---------------------------------------------------------------------------------**//** * @description Set some basic default values. e.g. color's RGB values * @bsimethod Bentley Systems +---------------+---------------+---------------+---------------+---------------+------*/ RENDLIB_EXPORT void P_SetDefaults ( );
Answer Verified By: Actual Yang
