Dismiss Projectwise export dialog in Microstation via VBA?
Hi all,
I currently use Modal Dialog Events Handlers in Microstation VBA to populate and dismiss dialogs that open during export processes. Now that I have Projectwise integration activated, this dialog process is taken over by a Projectwise dialog that requires me to manually cancel it to enable the Macro to continue.
Can anyone help me with some MVBA code to dismiss these PW dialogs to allow for full automation of export macros (if possible)?
Mark
