I have worked with Microstation before but everything was setup for me. I started a new position and trying to get Microstation setup to begin design for the company. I will be only working in 2d so I opened the 2d seed file. Every file I open has the same result. When I open the files and begin drawing a line, the line can only be drawn at a certain angle and the line disappears into the back of the screen. It has to be a setting in my workspace but I can't figure out what setting it is.
Unknown said:When I open the files and begin drawing a line, the line can only be drawn at a certain angle
You've posted to the Programming Forum, but you would do better to post to the MicroStation Forum.
