Hi all,
I am new to Microstation development, and recently i want to develop an extension which is to "read" DGN file data(geometry, properties, reference...), i am not familiar with the MDL development environment( especially about the make file, resource file..), and would like to start with an C# addin, this environment is familiar to me and i can quickly start and focus on my logic. but i am not sure whether i have the same level access to the APIs, i have read a lot threads, wikis, and seems the MDL application have more api access to the DGN file filed. what i need is just to read the DGN file information(geometry, properties, references..)
can any expert help me confirm whether i can get the same level api access if i start with an C# addin, from the DGN file "read" perspertive, access Bentley DGN files with full fidelity.
and by the way, the DGN file is generated by AECOsim.
thanks,
Rick
Unknown said: I am new to Microstation development
Which version (e.g. v10.x.y.z) of MicroStation? You have tagged .dgn V8, but the DGN file format is the same in V10 as in V8.
I am using the V8 version of microstation. thanks,
Unknown said:I am using the V8 version of microstation
There is no native .NET API for MicroStation V8 (MicroStation CONNECT provides an extensive .NET API).
To write a C# AddIn, you can call the VBA API via an InterOp, or MDL functions using P/Invoke.
thanks Jon for your reply.
yes, i call the VBA API via an interop, my question is that whether the VBA API has full access to the DGN file(access Bentley DGN files with full fidelity), what i get from the sdk document is that the MDL api has the full access, so whether the MDL API always has an equivalent VBA API?
Hi Rick,
as Jon wrote, there is not "real NET API" available in MicroStation V8i and Interop is used. So as you wrote already, what is available in C# is equal to VBA API, plus some extra classes (but not documented) to integrate WinForms into standard MicroStation dialog system (e.g. to create own Tool Settings dialog).
Because it's not C/C++ versus NET, but C/C++ versus VBA and VBA is macro and rapid prototyping tool, not full featured API, so they don't offer the same functionality and when using VBA (directly or the same API through Interop), many limitations exist.
In CONNECT Edition a new NET API was introduced and it provides access more similar (but not equal) to native C/C++ API. Old Interop is still maintained and part of official NET API.
I guess it's not defined anywhere, but "API priority and features" are:
Unknown said:my question is that whether the VBA API has full access to the DGN file(access Bentley DGN files with full fidelity)
No, it does not. There are plenty of features (e.g. XAttributes, advanced solid modelling etc.) that are not available in VBA.
Unknown said:o whether the MDL API always has an equivalent VBA API?
It has not, because it's not the role of VBA API.
Unknown said:if i start with an C# addin, from the DGN file "read" perspertive, access Bentley DGN files with full fidelity
In my opinion it should be solved in opposite direction: If there is a problem or task that has to be solved, a proper tool tool has to be found and used. If you need tight integration and full access to DGN data, in V8i native code (which means "old C" and "new C++ MicroStationAPI") should be used. Or if you can migrate to CONNECT Edition, NET will offer you much better access, but because it's quite new API, it's not clear whether really everything is available (but it's still 10x better and richer API comapring to Interop).
Unknown said:and by the way, the DGN file is generated by AECOsim.
All MicroStation APIs provides access to MicroStation data. It does not help you to interpret AECOsim data structures (I guess you mean Building Designer), it's the role of AECOsim BD API. For example (my knowledge of AECOsim BD is limited), using MicroStation C/C++ API you willl receive cell with plenty of element data (I guess XAttrbiutes) in in, but the API will not tell you it's a wall with windows with some parameters. This interpretation is inside AECOsim BD API.
With regards,
Jan
Answer Verified By: Rick cheng
MDL and the MicroStationAPI are more complete than VBA.
Unknown said:My question is that whether the VBA API has full access to the DGN file
VBA is provided to automate user interaction. It does not provide in-depth functionality afforded by MDL (for example, the Dependency Manager). However, VBA does provide some functionality that is not available through MDL and the MicroStationAPI (for example, element properties using a PropertyManager).
So, depending on what you mean by 'full access', the answer is indeterminate.
thanks Jan for the clarification, and you reply did answer my question. and i have a follow question regard the api, i found in the sdk document, there is a document named MicrostationAPI which is the api we are talking about, and the other document is named "MDLAPIFunctionReference", i guess those MDLAPI should be equal to MicrostationAPI, is it true?
and can i write an C++ addin which will reference MicrostationAPI, so i can have more broad api access? is there any sample?
Unknown said:i guess those MDLAPI should be equal to MicrostationAPI, is it true?
No, these API are not equal in V8i. The history of API development leads to this confusion (and was solved mostly in CONNECT Edition):
I hope it will become clear based on this short history overview (ignoring digressions like Java API / JMDL etc.):
There are some philosophy differences between MDL C API and MicroStation C++ API (e.g. how elements are identified), but it's still the same memory model, so it's easy to work in C++ API and when necessary, to pass an element (e.g. like pointer to Element Descriptor) to C function.
Unknown said:and can i write an C++ addin which will reference MicrostationAPI, so i can have more broad api access?
It's not called addin, because it's not NET code derived from Addin class. Usually it's called just "application" or "MicroStation application".
Because you can use C and C++ APIs at the same time, there is no reason to distinguish between them. In reality it's easier to use C API in V8, because it's better documented and there are more examples. But some features are available in C++ only (and vice versa).
To create native code application for V8i, you need Visual Studio 2005 Professional. I know some develoeprs use VS2008 instead of VS2005, but you should be aware of potential threats because of different C runtime versions.
Unknown said:is there any sample?
MicroStation SDK is delivered with some examples. The most of them are MDL C oriented, but I guess some from them use also C++ API.
thanks for the detail explanation, I am clear now.
