I use a Key-in in script file when it runs the element selection tool (powersel) is gone so I have to reload. In the VBA routines you can have it reloaded automatically
SCRIPT:
set weight toggleselview allupdate all
Works fine, but have to reload the Element selection
would like to add a line to the script that loads the above ?
Using VBA on similar example: it will reload the element selector or Powersel not sure of correct name? It is under Tools>Selection>Element Selection
Hope this question is clear ?
The Keyin command for that tool is CHOOSE ELEMENT
Does that get you what you want?
MaryB
oh yes, that is it and I will add to the script file ..... So thank you for the help !!!!!
I had looked and looked. Sure is wonderful to have tech support from so many folks who really know the answers. Jan has helped me so much with MVBA things too.,
Version: MicroStation V8i SS 10
RJB Phillips III (Richard) Praise the Lord for His Mercy and grace in Christ Jesus
