Declare Function mdlDialog_completionBarOpen in stdmdlbltin.dll not working in CONNECT
Hi!
So I'm trying to move our vba scripts from old v8i to Connect edition. Most of the things work just fine but when I'm trying to run a script which is using
Private Declare PtrSafe Sub mdlDialog_completionBarUpdate Lib "stdmdlbltin.dll"
(ByVal dbP As Long, ByVal msgText As String, ByVal percentComplete As Long)
Private Declare PtrSafe Function mdlDialog_completionBarOpen Lib "stdmdlbltin.dll"
(ByVal messageText As String) As Long
Private Declare PtrSafe Sub mdlDialog_completionBarClose Lib "stdmdlbltin.dll"
(ByVal dbP As Long)
Microstation gives me an error telling me that it didnt find an entrypoint for mdlDialog_completionBarOpen in stdmdlbltin.dll .
Usually I would have looked into the mdl documentation and would hopefully find some Declare statements at the bottom of the page telling me that there is another lib or that I have used wrong types. But I couldn't find the mdl docs (which makes sense as mdl is gone, right?).
Inside the MicrostationAPI documentation I found the function so I know it still exists. So my question is: which Lib should I use for Declare in VBA? Or better: how would I be able to look that up by myself? Or if it is just the wrong types: how could I look up the argument and return types that VBA Declare is expecting for each function?
As always I would be really glad if someone could help me with that stuff.
Stephan
Parents Reply Children
