Shape triangulation.
I use microstation V8i (SS3) and programming in MDL.
I have shape element in 3D, this shape is non coplanar.
When add fill:
After use function:
mdlMesh_newPolyfaceFromXYTriangulation
mdlMesh_convertToShapes
I received:
Blue triangle is redundant.
How to remove it using mdlMesh _... Api?
Any suggestions?
Regards.
  • Unknown said:
    I have shape element in 3D, this shape is non coplanar ... blue triangle is redundant
    The redundant triangle may be the result of analysing a non-planar shape using mdlMesh_newPolyfaceFromXYTriangulation().
    I recommend that you create a class that inherits from Bentley::Ustn::IElementGraphicsProcessor.  Override _ProduceFacets...
    virtual bool  _ProduceFacets (bool  isIndexedPoly) const override
      return true;
    Now call Bentley::Ustn::ElementGraphicsOutput::Process (elementHandle, yourGraphicsProcessor) for each element.  You will receive a list of triangular facets.
    Look in the MicroStationAPI help document for ElementGraphicsProcessor.
    Regards, Jon Summers
    LA Solutions
Reply
      return true;
    LA Solutions
