Entering Multiple Lines Using Notepad
I currently am able to find and replace text using the following code in Notepad, utilizing the batch process command in utilities, version V8i:
MDL SILENTLOAD FINDREPLACETEXT,CHNGTXT CHANGE DIALOGTEXT
FIND DIALOG SEARCHSTRING OLD TEXT HERE
FIND DIALOG REPLACESTRING NEW TEXT HERE
CHANGE TEXT ALLFILTERED
Thus far this code is working properly; however, If i want to replace the old text with new text that goes on multiple lines, I am not able to make it work.
For example:
Old text: The quick brown fox jumps over....
New Text: The quick brown [new line]
                 fox jumps over....
Is there a way of properly doing this by modifying the code above?
Thank you in advance.
Parents Reply Children
