I've done something wrong while editing my dialog resource. I'm seeing this message:
### Error: Duplicate: File=(G:\PROGRA~1\Bentley\MICROS~2\MICROS~1\mdlapps\AreaAnnotator.ma), TypeId=('xAtL') RscId=(20)
[Edit]
Well, it's an RTYPE_ExtAttrList, which I use to attach info bubbles and balloon to dialog items. Here's an example...
DItem_ComboBoxRsc COMBOBOXID_TextStyle = { NOCMD, LCMD, NOSYNONYM, NOHELP, MHELPTOPIC, HOOK_CBO_TextStyle, NOARG, 36, '', '', '', '', NOMASK, 0, 12, 4, 0, 0, COMBOATTR_READONLY | COMBOATTR_DISPLAYALLCOLUMNS | COMBOATTR_FONTBYCOLUMN | COMBOATTR_FULLWIDTH, TXT_cboTextStyle, 'g_vars.textStyle', { // Column Captions {14*XC, 36, ALIGN_LEFT, TXT_colTextStyle}, } } extendedAttributes {{ {EXTATTR_FLYTEXT, TXT_Flyover_TextStyle}, {EXTATTR_BALLOON, TXT_Balloon_TextStyle}, } };
However, I can't see any duplicate extendedAttributes, so the resource linker message remains a mystery.
I have seen this error (randomly) as well when remaking all (bmake -a) after adding a new resource:
"### Error: Duplicate: File=(E:\000_Loren\mdl\terraToolsCE\terraTools.ma), TypeId=('WIG_') RscId=(1)".
However,
buildoutput.txt
I've had similar problems with MicroStation not releasing file handles for certain types (SHP/DBF and KML) when using fclose(), reported it through a service request and it was fixed in subsequent versions. So I believe it's not a problem with the resource definition but with the MA file handle not being released/unlocked when unloaded in MicroStation.
